Ga door naar hoofdinhoud
HP ProBook 4520s Optical Drive Replacement
Wat je nodig hebt
  1. HP ProBook 4520s Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Optical Drive Replacement, Switch Cover: stap 3, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement, Switch Cover: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Optical Drive Replacement: stap 4, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Optical Drive Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Optical Drive Replacement: stap 6, afbeelding 1 van 3 HP ProBook 4520s Optical Drive Replacement: stap 6, afbeelding 2 van 3 HP ProBook 4520s Optical Drive Replacement: stap 6, afbeelding 3 van 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Optical Drive Replacement, Keyboard: stap 7, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement, Keyboard: stap 7, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. HP ProBook 4520s Optical Drive Replacement: stap 8, afbeelding 1 van 1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
  9. HP ProBook 4520s Optical Drive Replacement: stap 9, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement: stap 9, afbeelding 2 van 2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
  10. HP ProBook 4520s Optical Drive Replacement, Optical Drive: stap 10, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement, Optical Drive: stap 10, afbeelding 2 van 2
    • The housing for the optical drive is on the right of the device.
    • Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
  11. HP ProBook 4520s Optical Drive Replacement: stap 11, afbeelding 1 van 1
    • Use a metal spudger to push the optical drive to the right and partially out of the casing.
  12. HP ProBook 4520s Optical Drive Replacement: stap 12, afbeelding 1 van 1
    • Slide the optical drive outward from the 4520s.
  13. HP ProBook 4520s Optical Drive Replacement: stap 13, afbeelding 1 van 2 HP ProBook 4520s Optical Drive Replacement: stap 13, afbeelding 2 van 2
    • Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
Conclusie
Nicholas Caruso
314 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-3, Oliver Fall 2016 Lid van UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 24
Altijd: 2,469
