Inleiding
Updating your Wi-Fi Card can give you a faster connection and greater range. Allowing your computer to take full advantage of high speed internet.
Wat je nodig hebt
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
Één andere persoon heeft deze handleiding voltooid.
