Ga door naar hoofdinhoud
HP ProBook 4320t Clock Battery Replacement Guide
Wat je nodig hebt
  1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: stap 1, afbeelding 1 van 2 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: stap 2, afbeelding 1 van 2 HP ProBook 4320t Clock Battery Replacement Guide, Screws: stap 2, afbeelding 2 van 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: stap 3, afbeelding 1 van 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: stap 4, afbeelding 1 van 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: stap 5, afbeelding 1 van 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: stap 6, afbeelding 1 van 2 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: stap 6, afbeelding 2 van 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: stap 7, afbeelding 1 van 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: stap 8, afbeelding 1 van 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: stap 9, afbeelding 1 van 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: stap 10, afbeelding 1 van 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: stap 11, afbeelding 1 van 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: stap 12, afbeelding 1 van 1
    • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
  13. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: stap 13, afbeelding 1 van 1
    • Using your black spudger, gently press down and towards you until the battery slides out.
    • Put new clock battery in and reassemble.
Conclusie
Joshua
134 Reputatie
6 handleidingen geschreven
USF Tampa, Team 9-5, Blackwell Fall 2014 Lid van USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,003
