Shut the device off.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Voeg opmerking toe
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
Voeg opmerking toe
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Voeg opmerking toe
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
Voeg opmerking toe
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Voeg opmerking toe
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Voeg opmerking toe
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Voeg opmerking toe
  • Grip the printer hood and pull upward.
Voeg opmerking toe
  • Lift the scanning lid from the lower portion of the printer hood.
Remove torx screw on bottom of assembly in corner near touchsmart screen space.
Jeff - Antwoord
  • Leaving the ribbon connected, lift the sliding scanner off the track.
  • Pull the ribbon cable out of the slot on the scanner circuit board.
  • Insert the scanning piece into the rolling track.
Voeg opmerking toe
Conclusie
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
226 Reputatie
3 handleidingen geschreven
Cal Poly, Team 2-11, Propen Fall 2012 Lid van Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Leden
6 handleidingen geschreven
Één commentaar
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 10
Altijd: 1,225
