Ga door naar hoofdinhoud
HP Photosmart c4780 Motherboard Replacement
Wat je nodig hebt
  1. HP Photosmart c4780 Motherboard Replacement, Outer Shell Disassembly: stap 1, afbeelding 1 van 2 HP Photosmart c4780 Motherboard Replacement, Outer Shell Disassembly: stap 1, afbeelding 2 van 2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Photosmart c4780 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Photosmart c4780 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Photosmart c4780 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Photosmart c4780 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Remove the three uncovered T10 screws from the motherboard.
  11. HP Photosmart c4780 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Gently remove the seven cables that are attached to the motherboard using a plastic opening tool.
  12. HP Photosmart c4780 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Gently lift motherboard out of the slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
garrett hall
49 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-11, Propen Fall 2012 Lid van Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 4,133
