Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Één andere persoon heeft deze handleiding voltooid.
Één commentaar
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
