Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Set aside the ink cartridge carriage.
Remove the three T10 12mm Torx screws holding the paper guide to the printer body.
Lift the paper guide directly up to remove it and set it aside.
Set aside the printer base.
Flip the feed roller assembly over so that its bottom and so that the feed roller is on the left side.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
Does the encoder wheel gear have to be exactly in a certain position, or does it not matter?
