Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Één andere persoon heeft deze handleiding voltooid.
