Ga door naar hoofdinhoud
HP Photosmart c3180 Control Panel Circuitry Replacement
Wat je nodig hebt
  1. HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel of HP Photosmart c3180 printer: stap 1, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel of HP Photosmart c3180 printer: stap 1, afbeelding 2 van 2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 2, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 2, afbeelding 2 van 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 3, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 3, afbeelding 2 van 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 4, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 4, afbeelding 2 van 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 5, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 5, afbeelding 2 van 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 6, afbeelding 1 van 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 7, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 7, afbeelding 2 van 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 8, afbeelding 1 van 2 HP Photosmart c3180 Control Panel Circuitry Replacement: stap 8, afbeelding 2 van 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. HP Photosmart c3180 Control Panel Circuitry Replacement, Control Panel Circuitry: stap 10, afbeelding 1 van 1
    • Set aside the printer body.
    • Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
  11. HP Photosmart c3180 Control Panel Circuitry Replacement: stap 11, afbeelding 1 van 1
    • Using both hands, carefully lift the control panel circuit board from the top panel of the printer.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jim
1.590 Reputatie
10 handleidingen geschreven
Cal Poly, Team 20-30, Maness Fall 2011 Lid van Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 4,418
