Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
By opening up the printer by unscrewing a few screws.This will allow you to take the wireless card out of it's socket and replace it.
Onderdelen
Geen onderdelen opgegeven.
  1. Open the top of the printer as shown.
    • Open the top of the printer as shown.
    • The wireless card is located on the left side of the printer if you are viewing it from the front.
  2. Using the T9 Torx Security screwdriver bit, unscrew the 12 mm screw on the far left side on the top of the printer.
    • Using the T9 Torx Security screwdriver bit, unscrew the 12 mm screw on the far left side on the top of the printer.
  3. After unscrewing the screw, the left side will slide down revealing the wireless card.
    • After unscrewing the screw, the left side will slide down revealing the wireless card.
  4. Unscrew one 12mm screw and gently disconnect the wireless card from the motherboard. Unscrew one 12mm screw and gently disconnect the wireless card from the motherboard. Unscrew one 12mm screw and gently disconnect the wireless card from the motherboard.
    • Unscrew one 12mm screw and gently disconnect the wireless card from the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Charles
272 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-2, Lauer Fall 2014 Lid van Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,231
