Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Open the top of printer. The printer should appear as shown.
Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
Loosen the pieces around the edges before pulling to remove from the printer.
Pull the (4) trim pieces off and set them aside.
Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
Both clips will come unattached and you can set the scanner flap aside.
Lift the scanner glass piece from the printer and set it aside.
Gently pull the display screen away from the printer.
Locate & unscrew the two 12mm screws using the T9 Torx Security screwdriver bit.
Place thumb and forefinger where shown and pull this piece away from the printer.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Pull both wiring ribbons out from the display screen piece. This will separate the piece from the printer.
Push forward and down to release the retaining piece. This will detach the display screen from the front panel.
Set the display screen face down.
Locate and unscrew all four 12mm screws on the back on the display screen using the T9 Torx Security screwdriver bit.
Place hands as shown and push with your thumbs to detach the plastic from the screen.
Één andere persoon heeft deze handleiding voltooid.
