Ga door naar hoofdinhoud
HP Photosmart Premium C309g TouchSmart Display Screen Replacement
Wat je nodig hebt
  1. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement, TouchSmart Display Screen: stap 1, afbeelding 1 van 1
    • Open the top of printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 2, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 2, afbeelding 2 van 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 3, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 3, afbeelding 2 van 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 4, afbeelding 1 van 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 5, afbeelding 1 van 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 6, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 6, afbeelding 2 van 2
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 7, afbeelding 1 van 1
    • Gently pull the display screen away from the printer.
    • Locate & unscrew the two 12mm screws using the T9 Torx Security screwdriver bit.
  8. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 8, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 8, afbeelding 2 van 2
    • Place thumb and forefinger where shown and pull this piece away from the printer.
    • Do not pull it away too hard. The piece is still connected by wiring ribbon.
  9. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 9, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 9, afbeelding 2 van 2
    • Pull both wiring ribbons out from the display screen piece. This will separate the piece from the printer.
    • Use tweezers if necessary.
  10. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 10, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 10, afbeelding 2 van 2
    • Push forward and down to release the retaining piece. This will detach the display screen from the front panel.
  11. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 11, afbeelding 1 van 1
    • Set the display screen face down.
    • Locate and unscrew all four 12mm screws on the back on the display screen using the T9 Torx Security screwdriver bit.
  12. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 12, afbeelding 1 van 1
    • Lift the back of the display screen to remove it.
  13. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 13, afbeelding 1 van 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: stap 13, afbeelding 2 van 2
    • Place hands as shown and push with your thumbs to detach the plastic from the screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Laura
694 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-2, Lauer Fall 2014 Lid van Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Leden
5 handleidingen geschreven
Één opmerking
where can i get replacement part
fernando - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,177
