Ga door naar hoofdinhoud
Inleiding
Replacing the ink cartridge is easy and requires no technical skill or tools.
Required Tools
  • None
  1. In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. Press down on the head of the ink cartridge that needs replacing.  This will release the cartridge and allow you to pull it out. Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. Place the new cartridge into the slot and press firmly until it pops into place.
    • Place the new cartridge into the slot and press firmly until it pops into place.
Conclusie
Tim Wise
173 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-38, Forte Spring 2011 Lid van Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Leden
10 handleidingen geschreven
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Antwoord
the HP ink cartridge is 60. Does that make any difference???
April -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 11,001
