Ga door naar hoofdinhoud
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: stap 1, afbeelding 1 van 1
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: stap 2, afbeelding 1 van 2 HP Photosmart D110a Ink Cartridge Replacement: stap 2, afbeelding 2 van 2
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: stap 3, afbeelding 1 van 1
    • Place the new cartridge into the slot and press firmly until it pops into place.
Conclusie
Tim Wise
173 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-38, Forte Spring 2011 Lid van Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Leden
10 handleidingen geschreven
2 opmerkingen
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Antwoord
the HP ink cartridge is 60. Does that make any difference???
April -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 12,219
