Ga door naar hoofdinhoud
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: stap 1, afbeelding 1 van 2 HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: stap 1, afbeelding 2 van 2
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: stap 2, afbeelding 1 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 2, afbeelding 2 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 2, afbeelding 3 van 3
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: stap 3, afbeelding 1 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 3, afbeelding 2 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 3, afbeelding 3 van 3
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: stap 4, afbeelding 1 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 4, afbeelding 2 van 3 HP Photosmart C4435 Ink Cartridge Replacement: stap 4, afbeelding 3 van 3
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: stap 5, afbeelding 1 van 2 HP Photosmart C4435 Ink Cartridge Replacement: stap 5, afbeelding 2 van 2
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: stap 6, afbeelding 1 van 2 HP Photosmart C4435 Ink Cartridge Replacement: stap 6, afbeelding 2 van 2
    • Close the ink compartment before using the printer.
Eindstreep
Kalvin Trac
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 283
