Ga door naar hoofdinhoud
HP Photosmart 935 Plastic Casing Replacement
Wat je nodig hebt
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: stap 1, afbeelding 1 van 2 HP Photosmart 935 Plastic Casing Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: stap 3, afbeelding 1 van 2 HP Photosmart 935 Plastic Casing Replacement: stap 3, afbeelding 2 van 2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: stap 4, afbeelding 1 van 1
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: stap 6, afbeelding 1 van 2 HP Photosmart 935 Plastic Casing Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: stap 7, afbeelding 1 van 2 HP Photosmart 935 Plastic Casing Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: stap 8, afbeelding 1 van 3 HP Photosmart 935 Plastic Casing Replacement: stap 8, afbeelding 2 van 3 HP Photosmart 935 Plastic Casing Replacement: stap 8, afbeelding 3 van 3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: stap 9, afbeelding 1 van 1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: stap 10, afbeelding 1 van 2 HP Photosmart 935 Plastic Casing Replacement: stap 10, afbeelding 2 van 2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
Conclusie
Clay Young
233 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-13, Forte Spring 2012 Lid van Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 1,739
