Ga door naar hoofdinhoud
HP Photosmart 5520 Maintenance
Wat je nodig hebt
  1. HP Photosmart 5520 Maintenance, Centering the printhead: stap 1, afbeelding 1 van 2 HP Photosmart 5520 Maintenance, Centering the printhead: stap 1, afbeelding 2 van 2
    • Turn on the printer
    • Lift up the scanner glass and the top cover, then the printerhead is centered in the printer case
    • Remove the ink cartridges.
    • Unplug the printer but do not turn off with the front I/O button. Otherwise the printhead will return to its park slot.
    • Use adhesive tape to fix together the scanner glass and the cover
    Druckkoüpf fährt nicht in Mittelstellung? Wie kann man das beheben?
    claudiakornetzky - Antwoord
  2. HP Photosmart 5520 Maintenance, Removing the top cover: stap 2, afbeelding 1 van 2 HP Photosmart 5520 Maintenance, Removing the top cover: stap 2, afbeelding 2 van 2
    • Gently pull on the hook. Retain the scanner glass and the cover once the hook is removed.
    How to clean under the glass
    Kathy Huneycutt - Antwoord
    Need to know to clean under glass it has Cobb
  3. HP Photosmart 5520 Maintenance, Removing the printer hood: stap 3, afbeelding 1 van 3 HP Photosmart 5520 Maintenance, Removing the printer hood: stap 3, afbeelding 2 van 3 HP Photosmart 5520 Maintenance, Removing the printer hood: stap 3, afbeelding 3 van 3
    • Unscrew the 7 torx screws. Do not forget the one under the printer label (You have to remove the printer label. Lower right corner).
    • Push the clips at the rear of the LCD panel and pull the LCD panel outwards at the same time. The clips can be felt, but not seen underneath the plastic on which the HP label is visible in the middle picture. A fourth picture would help here.
    • Then, pull the ribbon connected to the LCD panel to disconnect the LCD panel from the printer.
    • Remove the 2 remaining torx screws hidden by the LCD panel
    • See where are clips (Blue arrows)
    First push the three clips (blue arrows), then take off the panel, then remove the two remaining torx.
    Erik Mulder - Antwoord
    Cette démonstration est particulièrement mauvaise. Sur ma 5520, il n’y a pas moyen d’accéder aux “clips” sans casser les 2 supports de l’afficheur LCD. Plutôt que de risquer de casser quoi que ce soit et d’aggraver la situation, j’arrête là avant d’obtenir une info complémentaire sur le démontage PROPRE du LCD.
    JOUFFROY - Antwoord
    C'est le moment délicat. On a trés peu de visibilité de l'arrière du panneau, pourtant les 3 clips sont là, un de chaque côté et un en haut. À tâtons avec un doigt on arrive en poussant chaque clip vers l'intérieur, puis le panneau vers l'extérieur.
    Merci à l'auteur de ce tutoriel qui m'a permis de démonter mon imprimante qui malheureusement n'est pas facilement irréparable….
    Bien à
    Marc Petitfour -
    Download the HP printer/ scanner doctor, just solved my problem with black ink not printing properly. Lines through photos etc.
    Smythers
    William Smyth - Antwoord
    Beim Lösen des LCDs brauche ich 3 Hände!!!!
    Erich Pfefferle - Antwoord
    C’est en effet le moment le plus délicat : j’y suis arrivé finalement en trouvant seulement le clip central et en pesant dessus avec le doigt et cela a suffit à tirer le panneau qui est sorti de lui-même. Merci à Marc P. qui m’a poussé à persévérer.
    Pierre Aubert 12.06.2021
    Pierre AUBERT - Antwoord
    Merci beaucoup à l’auteur de ce tuto . Grâce à lui, j’ai démonté la tête sans difficultés voici plus de 2 ans et j’ai réussi à la nettoyer. J’ai donc une tête neuve d’avance ! Par contre, aujourd’hui, une petite fuite d’encre noire s’est manifestée. J’ai re-démonté pour nettoyer mais je ne vois rien de concret. Je remonte et place l’imprimante dans un plateau avec tissus d’épongeage !
    Pierre
    Pierre Roger - Antwoord
    Bonjour : très bon tutoriel, mais ..., manquent des précisions ; Etape 2 : comment est fixée et se démonte cette charnière-glissière : vissée ou entrée à la force ? Etape 3 : MISSION IMPOSSIBLE pour le démontage de l'écran LCD ! combien de clips (je n'en "devine" qu'un, en haut et au centre ... ) ? à quoi ressemblent-ils ? comment faut-il agir sur ces clips, "à tâtons et en aveugle" ? etc ... ; je n'ai pas réussi à franchir cette étape (en dépit du temps passé et de la force exercée ... ) qui demande des explications supplémentaires ...
    Bref, un dessin représentatif desdits "clips" et un schéma du sens des forces à exercer seraient bienvenus, ... et éviteraient la casse !
    Merci : MJL
    MJL - Antwoord
    - Please develop "step 3", disassembly of the LCD screen; show the "clips"... ; indicate how to act and force on them ...
    MJL - Antwoord
    I used a long, very thin & small flat screwdriver behind each side clip to release it without applying too much pressure which might break the clips off
    r b - Antwoord
    • Now the cover can be removed and expose the inner workings of the printer.
  4. HP Photosmart 5520 Maintenance, Removing the print head: stap 5, afbeelding 1 van 3 HP Photosmart 5520 Maintenance, Removing the print head: stap 5, afbeelding 2 van 3 HP Photosmart 5520 Maintenance, Removing the print head: stap 5, afbeelding 3 van 3
    • Remove the springs that maintain the print head.
    • Remove the print head by pulling on the ribbons. These are delicate and easily damaged if attempting to clean with alcohol.
    • In case you want to replace the print head, the spare part reference is: CN688A
    • When inserting the print head after cleaning or replacing, make sure the horizontal plastic ribbon is between the plastic guides, as shown in the last picture. Getting this wrong may cause the print head to jam when you put the power back on at the end.
    Great instructions to this stage. Underside of print head can be washed under warm running water if you keep the end with the electronics dry.
    sjgroom - Antwoord
    It can also be interesting to gently clean the thin plastic band.
    Paul - Antwoord
  5. HP Photosmart 5520 Maintenance, Cleaning the print head park slot: stap 6, afbeelding 1 van 3 HP Photosmart 5520 Maintenance, Cleaning the print head park slot: stap 6, afbeelding 2 van 3 HP Photosmart 5520 Maintenance, Cleaning the print head park slot: stap 6, afbeelding 3 van 3
    • The printer has an automatic feature to clean the print head. Usually, there is a lot of ink (Probably melt with dust) in the area where the print head is cleaned
    • Remove 4 of the 5 torx screws as shown in the picture. As given in a user comment, the top right one serves to join the two pieces of this part.
    • Assuming the print head is now removed (Not shown on the picture), now gently tip the plastic plate and remove it
    • If you didn't put gloves yet, it is time to do it !
    • Now, push the carriage that holds the print head cleaning system (Red arrows)
    • The carriage that holds the print head cleaning system is now clean (Last picture)
    thank you for that information, there is a video on you tube too but not in English but he shows it pretty well. my cartridges are stuck in the docking area, so only need to get to there, hopefully the system will work afterwards.
    rustic_girl2003 - Antwoord
    I did what so advice to do. But it is not working at all even cleaned it with ultra-soon bath. Nothing is helping what to do?? Ronald
    Ronald de Bruin - Antwoord
    You need to MOVE UP the advice about putting on gloves. Otherwise, well done & thank you.
    kevinbarnes1 - Antwoord
    Followed instructions …very clear! Now I am getting cartridge jam message and cannot get rid of it. Whirring noise before message comes up.
    Walter Yamka - Antwoord
    OMG the print head cleaning area was so full of old ink. It really needed removing and soaking but could not see how to remove it under the sea of old ink so had to mop the worst off with paper towel and reassemble. Works OK now.
    sjgroom - Antwoord
    Instructions work well. Fortunately, the ink muck is water soluble. After cleaning, (cleaning carriage as well as the printhead) I continue having No Black Ink delivered during printhead cleaning routine or when I try to print using “Black Ink Only”! Next option is print head replacement or a trip to Best Buy to buy a Win10 printer.
    Thank you,
    “Skuz”
    John Skuz - Antwoord
    Comment pouvez-vous écrire que le chariot est maintenant propre alors que vous n’avez pas indiqué comment enlever l’encre et la poussière collée? Ce chariot peut-il être démonté? Si oui, comment afin de le nettoyer? Merci.
    JOUFFROY - Antwoord
    Merci beaucoup, très bien expliqué. Tout est propre, malheureusement la cartouche noire ne fonctionne pas.
    Je suis allée dans les paramètres de l’imprimante “type de papier” , qualité d’impression” ,”plus foncé/plus clair” etc.. je dois au minimum choisir “qualité optimun et “le plus foncé” pour avoir un résultat gris pâle.
    Par contre si je choisis qualité “photo” j’obtiens une impression noire et correcte…
    de Lacheisserie - Antwoord
    There is a little ink pump which removes ink to the right side and soaks a sponge if that sponge is full of ink that starts to sip everywhere. You can remove the sponge and rince it then dry it.
    Cad Axe - Antwoord
    When the instructions state “remove the five torq screws”, the one on the top right of the photo should not be removed (so, remove only four). It serves only to keep two pieces of plastic together and does not hold the plate in the machine.
    Peter Groves - Antwoord
    Nach dem zusammensetzen habe ich ein Problem mit dem Schlitten. Beim Start direkt aus der Parkposition heraus knallt es und ich bekomme immer die Fehlermeldung “Patronenwagen blockiert”. Beim manuellen Schieben merkt man auch, dass irgendwo ein kleiner Widerstand ist. Was kann ich beim Zusammensetzen falsch gemacht haben?
    Marco Trampe - Antwoord
    hallo marco, habe haargenau das gleiche problem.
    wurde Ihr problem gelöst ? & wenn ja wie ??
    volker adam -
    Hallo Marco, hallo Volker,
    ich merke zwar keine Widerstand, sondern ledigleich, das sich der Schlitten beim verlassen der Parkposition etwas anhebt (scheint aber an der Führung zu liegen), ansonsten kann Euren beschrieben Fehler aber bestätigen. Hat einer von Euch Beiden bereits eine Lösung gefunden?
    Gruß Martin
    Martin Biastoch -
    auf der Rückseite vom Schlitten ist im oberen Bereich ein schwarzer Sensor, durch den das transparente Band durchgeführt werden muss. Mein Band lag unterhalb des Sensors, deshalb funktionierte es bei nicht. Nun läuft der Schlitten wieder gewohnt “langsam” und knallt nirgends gegen.
    Leider druckt bei mir der Drucker auch nach Reinigung des Druckkopfes immer noch nicht.
    Martin Biastoch -
    After I cleaned the printhead many times without more succes then before, I replaced it now with a new one. But STILL it is not printing black!
    I tried 4 new black cartridges already. The other colors work fine, but just not black. I have the newest firmware running. Has anyone another idea?
    donchu - Antwoord
    donchu, maybe a tube in the purge unit of your printer is blocked. I recently watched this helpful video because I had the same problem with the black ink not printing.
    https://youtu.be/d4JzsDWEbZc
    It is a bit messy, but maybe worth a try.
    Misch Magnifique -
    The printer is very stubborn ! after changed the head it says “ the head is damaged call hp assistance “ :-( is there a way to reset such a printer ?
    serge_faure - Antwoord
    Très bien expliqué et pas de problème particulier. Par contre, pas de changement au niveau de ma défaillance de fonctionnement, pas d’impression de la cartouche d’encre noire. Comme ce n’est pas trop compliqué à changer, j’ai commander une tête d’impression neuve, je verrai bien si j’ai raison d’insister…
    Dom - Antwoord
    Bonjour, J’ai une imprimante hp5520. Depuis plusieurs semaines , elle ne fonctionne plus. j’ai nettoyé les têtes des couleurs. Elle ne fonctionne toujours pas et notamment pour la couleur noir. Hier, je me suis rendue compte après un xxx nettoyage, qu’il y avait de l’encre de partout à droite de la cartouche. Je n’ai pas l’impression que ma cartouche à fuit. D où provient cet encre ? Et comment faire repartir mon imprimante qui jusqu’alors m’avait donné entière satisfaction. Merci pour votre aide
    ALLIER - Antwoord
Conclusie
62 andere personen hebben deze handleiding voltooid.
DrNox
1.740 Reputatie
2 handleidingen geschreven
41 opmerkingen
A l'étape 3, je n'arrive pas à retirer l'écran LCD. quand on me dit de pousser les deux clips à l'arrière, je ne vois les pas. tout semble solide et j'ai peur de casser quelque chose en forçant. comment franchir cette étape?
Joeblues - Antwoord
J'ai aussi eu un peu de difficulté à enlever l'écran LCD. Il ne faut pas hésiter à tirer dessus. Quand un clip est enlevé, les autres viennent plus facilement
LENNON -
Bonjour : très bon tutoriel, mais ..., manquent des précisions ; Etape 2 : comment est fixée et se démonte cette charnière-glissière ? Etape 3 : MISSION IMPOSSIBLE pour le démontage de l'écran LCD ! combien de clips ? à quoi ressemblent-ils ? comment faut-il agir sur ces clips, "à tâtons et en aveugle" ? etc ... ; je n'ai pas réussi à franchir cette étape qui demande des explications supplémentaires ... Merci : MJL
MJL -
J'ai étais ravie d'avoir ce tutoriel entre les mains car j'avais de gros problèmes et la tout est très bien détaillé en image c'est parfait même les références pour les pièces à changer d'indiquer c'est très bien
quentinseguela - Antwoord
The print head cleaning system carriage can be completely removed. Need to push the carriage to back of printer. Remove screw in back right corner, next to the black cylindrical pump with rubber hoses, and another in the gear assembly that runs this pump. Then wiggle and remove this pump/gear assembly. Now the carriage can be moved forward on the track till a slot allows getting past a small metal shaft and a gear. Now you can clean it in the sink with hot water. Be careful to put the two springs back on this carriage before putting it back into the printer.
And be sure all the tubing will freely flow water, or the pumping action will not work!
John Taft - Antwoord
Hi John, Thanks for your detailed instructions. I went as far as removing the pump/gear assembly. But whatever I tried, I could not manage to take out the "print head cleaning carriage". A photo would help if you have. Thanks & Merci! Chris
Christian RAPHALEN -
The instructions were very good. The most difficult part, strangely, was getting the LCD panel clips out. Good work. Thanks!
joespitzak - Antwoord
Black is completely blocked. It was printing before I put in a new cartridge. I got as far as removing the top panel torque screw, but no matter what I do, I cannot get the LCD panel clips to budge to get at the last screw. It is impossible to release them all at the same time. Any advice appreciated. Thank you.
Paul Williams 26 August 2017
Paul Williams - Antwoord
Hey Paul, the first time I did this I couldn’t get the LED panel off either. At that time I found there was enough flexibility in the cover to lever it up from the rear sufficiently to reach inside and remove the printhead. Not ideal, but do-able. The next time (today in fact) I realised that it was possible to reach a finger inside the carapace at the front and toggle the lower right hand clip holding the LED which, once released, made it easy to unclip the remaining clips. Much easier! However, having now done this twice, I have decided to buy a new printhead (on eBay, from China, US$15 with free shipping).
John -
Good instructions, but after reassmbly, I get a message that there is a cartridge jam, and I can't get it to work properly again. My initial issue was that the black ink wasn't working (but had plenty of ink left), so I was trying to clean out the printer head. But now I have no way of knowing if that addressed the initial issue.
Julie O'Meara - Antwoord
Carriage Jam results from failing to reposition the guide robbon between the sensor assembly on the print head cradle.
There are 2 black blocks at the top of the circuit board at the rear of the print head/cartridge cradle. The plastic guide ribbon needs to be between the two blocks.
Marek Reardon -
having done all cleaning the printer is going through all the the motions and just returning a blank sheet even though it is printing the diagnostic sheet perfectly regards EJL
Eamon joseph LANDY - Antwoord
Thank you for your help. I am upset: HP clearly made it difficult for the users to fix their stuff. I mean: screw hidden behind a label, cables very difficult to put back etc etc This company do not respect the customers nor the environment.
Julien SAMIER - Antwoord
Instructions were good until this point: “Remove the 2 remaining torx screws hidden by the LCD panel…See where are clips (Blue arrows).” No explanation on how to remove the LCD panel and no blue arrows in the diagram pointing out clips. Did the author take a doobie break? Thanks to the comments, I figured it out. However, pulling the ribbons off the print head broke one of the plastic plugs off the printhead, forcing me to order a new one. With Mr. HP in pieces and doubts about a new printhead fixing this boat anchor, I’m strongly tempted to slam dunk it into my trash receptacle and be done. Thanks HP for another stunning piece of crap.
Albert Einstein - Antwoord
Merci pour ce tutoriel ! Mon imprimante avait vraiment besoin d’un petit nettoyage, il y avait de l’encre partout !
J’ai fait attention lorsque j’ai remis tout en place, et pourtant au redemarrage, l’imprimante me signale un blocage charriot (alors que le charriot se déplace librement sans problème à la main et grace aux moteurs). Auriez-vous une idée ? Serait-ce le ruban horizontal de la tête d’impression qui aurait été endommagé ?
Merci beaucoup !
regimbaud - Antwoord
Does this mean we leave the plastic panel out ?
It just says remove the plastic panel, and the printhead carriage is now clean !!
To people struggling with the LED panel; I lift the panel as i’m trying to push the catch in the back. This seems to make it easier to get the catch back.
Det Dis - Antwoord
Great instructions. Got printer working again after the black print head completely dried up.
sjgroom - Antwoord
I removed the print head cleaning carriage assembly that slides fore and aft on the right side of my hp 5520 printer. After cleaning the plugged black ink tube that is attached to it, I’m ready to install it. PROBLEM: There are 2 springs on this unit…one on the side which I reconnected. The other is a smaller (weaker) spring that goes on the bottom of the unit. I see where the one end of the spring attaches but cannot figure out where to connect the other end. Any help would be greatly appreciated.
Steve - Antwoord
Ça fonctionne aussi très bien pour une HP Photosmart 5515.
Paul - Antwoord
Just reassembled my 5520 after installing a new printhead; unfortunately I am now receiving the message that “the cartridge access door is open” and it is not. The mechanical part of the system is in working order so it seems that the sensor itself has failed. Is there a fix for this? Yes, I have done a hard reboot multiple times but still receive the error. Help please.
Bill Fleming - Antwoord
Did you find where to put it? The same part appeared in my sink as I cleaned the larger panel - it goes somewhere touching that panel, I’m sure, but it is not obvious where! It would be helpful if the generally very clear instructions warned about this and showed where this rogue part fits in.
Peter Groves -
link doesn't work anymore but if this is the same part I had - it's missing in the image but I'm 99% sure it goes where the screw hole that doesn't have a screw is circled in the top right (pictured in the last step). not sure if this part is vital though
just for future reference, seeing as this is an old comment
Wessel -
What if you let your idiot friend change cartridge and they shut printer off instead of unplugging it?
FallenAngel69 - Antwoord
Bonjour, mon imprimante ne prend plus le papier car les 4 galets noir du fond ne tournent plus tout seul. Une idée de comment réparer ça ?
Hello, my printer does not take the paper because the 4 black pebbles from the bottom no longer turn alone. An idea of how to fix that?
sifus - Antwoord
Bonjour savez-vous où se trouve le capteur de fin de course, car j'ai une erreur récurrente et j'aimerais pourvoir changer ce capteur .
mathis vergnaud - Antwoord
Bonjou
je viens de faire l’ensemble du tuto après la remise en service j’ai un pb le chario saute du coup j’ai un message qui me demande de verifier le chariot de le pousser de droit à gauche à fond (aide sur l’ecran) rien ni fait
Help
merci d’avance
breuil_j - Antwoord
bonjour j ai le même problème que faire?
marc.vachet -
tuto génial très bien explique et facile a effectuer
A l’heure ou l’on veut sauver la planète il ne faudrait que des tutos comme celui ci pour tous les produits de la vie
milles merci
gilbert
gilbert postal - Antwoord
j’e n’ais pas encore fait ma maintenance mais l’utilitaire est vraiment détaillé dans ce tutoriel merci encore de nous aider.
saganogo soiliyo - Antwoord
non riesco a rimontare la striscia LCD, dove la inserisco lei non lo spiega purtroppo.
Nev Jack - Antwoord
Recht herzlichen Dank. Ich war schon am verzweifeln, die Tinte ist beim Drucker schon hinten rechts hervor gekommen und ich bring den oberen Teil vorne beim Display nicht ab, auch das unter dem Bezeichnungs- Schild vom Drucker eine Schraube ist, ohne ihrer super Reparatur Anleitung hätte ich das nie geschafft. So super beschrieben und abgebildet, ein Traum, danke danke danke, mit ganz freundlichen Grüßen aus Österreich aus Graz Eduard Konrad
Eduard Konrad - Antwoord
Thanks ifixit cleaned my HP5520 without too much fuss following your clear instructions….cheers.
Tony
Tony - Antwoord
J’ai nettoyé et remonté l’imprimante, mais l’écran ne s’allume plus. Comment réparer ?
Ich habe den mit Tinte versifften Drucker nach der Demontage hochkant in die Duschwanne gestellt (Elektronik nach oben) und die ganze Tinte mit der Duschbrause herausgespült. Hat eine Zeit gedauert bis nur noch klares Wasser aus dem Drucker kam. Dann noch den seitlichen Schwamm herausgezogen und ausgespült. Dann alles gut getrocknet und zusammengebaut, nun ist der Drucker blitzblank sauber und druckt auch wieder einwandfrei, ohne dass unten Tinte ausläuft!
Schwarze Finger waren allerdings nicht zu vermeiden ;-)
Rodolfo Stieglitz - Antwoord
Bravo pour ce tuto très efficace. Mon imprimante et moi vous disons merci
Lollipop xxx - Antwoord
dO YOU KNOW WHERE i CAN OBTAIN A SERVICE MANUAL (SCHEMATIC OF MAINBOARD)
Garth Notestine (Xerxes) - Antwoord
this is very nice. I could able to it. Now I want to learn/know about full dis assembly of electrical circuit board from th e printer . Please give th e instructions . Thanks
G Lakshmana Raju - Antwoord
I somehow ended up with a rogue torsion spring and I have no clue where it came from... I'm not sure if it would solve this, but after getting the carriage unstuck, my printer still refuses to work
Wessel - Antwoord
MJL - Antwoord
Bonjour,
pour infos, je sais démonter et remonter une Imprimante HP c3100 séries année 2010 2020.
Elle ne prenais plus le papier.
Je n'ai pas effectué de vidéos, mais quand j'aurais le temps, j'en publierai une.
Par contre, demander et je réponds aussi.
Bonne journée.
norton - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 28
Afgelopen 7 dagen: 213
Afgelopen 30 dagen: 1,019
Altijd: 143,777
