Ga door naar hoofdinhoud
HP Pavillion dm4t-2100 Memory Card Replacement
Wat je nodig hebt
  1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavillion dm4t-2100 Memory Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Memory Card Replacement: stap 2, afbeelding 1 van 3 HP Pavillion dm4t-2100 Memory Card Replacement: stap 2, afbeelding 2 van 3 HP Pavillion dm4t-2100 Memory Card Replacement: stap 2, afbeelding 3 van 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: stap 3, afbeelding 1 van 2 HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: stap 3, afbeelding 2 van 2
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  4. HP Pavillion dm4t-2100 Memory Card Replacement: stap 4, afbeelding 1 van 2 HP Pavillion dm4t-2100 Memory Card Replacement: stap 4, afbeelding 2 van 2
    • Lift black cover overlaying memory chip.
    • Spread the tabs on each side of the memory slot to release the module.
    • Remove memory by pulling the memory out at an angle, until completely detached.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 261
