Ga door naar hoofdinhoud
HP Pavillion dm1-3010nr Keyboard Replacement
Wat je nodig hebt
  1. HP Pavillion dm1-3010nr Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Keyboard Replacement: stap 2, afbeelding 1 van 1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. HP Pavillion dm1-3010nr Keyboard Replacement: stap 4, afbeelding 1 van 2 HP Pavillion dm1-3010nr Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. HP Pavillion dm1-3010nr Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. HP Pavillion dm1-3010nr Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Pavillion dm1-3010nr Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
Conclusie
Rosalia Olga Dupont Ayala
210 Reputatie
1 Handleiding geschreven
UC Davis, Team S7-G1, Lore Fall 2018 Lid van UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 663
