Ga door naar hoofdinhoud
HP Pavillion G7-2235DX Keyboard Replacement
Wat je nodig hebt
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Pavillion G7-2235DX Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Pavillion G7-2235DX Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Bre'Anna Sanders
113 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-7, Leahy Fall 2016 Lid van USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 61
Altijd: 2,668
