Wat je nodig hebt
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use your fingers.
Separate the keyboard and bottom panel.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using tweezers, disconnect the left speakers from the motherboard.
Remove the left and right speakers from the laptop.
