Ga door naar hoofdinhoud
HP Pavilion ze4530US Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion ze4530US Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: stap 6, afbeelding 1 van 1
    • You have successfully removed the keyboard.
Conclusie
Sonny Sem
356 Reputatie
3 handleidingen geschreven
Texas Tech, Team 38-5, Bennett Fall 2016 Lid van Texas Tech, Team 38-5, Bennett Fall 2016
TTU-BENNETT-F16S38G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 152
