Ga door naar hoofdinhoud
HP Pavilion zd8000 Switch Cover Replacement
Wat je nodig hebt
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: stap 2, afbeelding 1 van 2 HP Pavilion zd8000 Switch Cover Replacement: stap 2, afbeelding 2 van 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: stap 3, afbeelding 1 van 2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: stap 3, afbeelding 2 van 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: stap 4, afbeelding 1 van 2 HP Pavilion zd8000 Switch Cover Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: stap 5, afbeelding 1 van 2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: stap 5, afbeelding 2 van 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: stap 6, afbeelding 1 van 1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: stap 7, afbeelding 1 van 3 HP Pavilion zd8000 Switch Cover Replacement: stap 7, afbeelding 2 van 3 HP Pavilion zd8000 Switch Cover Replacement: stap 7, afbeelding 3 van 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Allie Menard
820 Reputatie
13 handleidingen geschreven
Cal Poly, Team 24-56, Amido Spring 2011 Lid van Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,109
