Ga door naar hoofdinhoud
HP Pavilion x360 m3-u103dx Motherboard Replacement
Wat je nodig hebt
  1. HP Pavilion x360 m3-u103dx Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Power the device off.
    • Flip the device over.
    • Using the plastic spudger, remove the rubber bumper to reveal 5 screws.
  2. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips screwdriver, remove 10 screws from the back plate.
    • Five 2.4 x 5.7 mm screws.
    • Five 2.8 x 5.0 mm screws.
  3. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Using the plastic opening tool, pry the keyboard upwards at the opening shown.
    • Then, using the metal spudger, pry around the rest of the keyboard until it is completely free.
    • Slowly, lift the entire keyboard up and away from the screen to reveal the connections and internals.
    • The connector ribbons can be damaged if the keyboard is lifted too high.
  4. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using the black nylon spudger, lift the retaining clip for each ribbon shown.
    • Lift the keyboard out of the device and out of the way.
  5. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a J000 screwdriver, remove 9 screws from the motherboard.
    • Using a Y1 screwdriver, remove the 10th screw from the top of the motherboard.
    • Tweezers can be helpful to pull screws from tight areas.
    • Grounding bracelets can prevent static from harming delicate electronics.
  6. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Using a spudger, flip the retaining clips for these two ribbons and gently pull them away from their sockets.
    • Using tweezers, gently pull this connector away from its socket.
  7. HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Gently lift the entire motherboard while tilting it to the left side of the laptop.
    • Disconnect the final plug from underneath the motherboard.
    • Lift the old motherboard from the laptop completely.
Conclusie
Nicholas Bassett
145 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G2, Hovde Fall 2019 Lid van IUPUI, Team S1-G2, Hovde Fall 2019
IUPUI-HOVDE-F19S1G2
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 549
