Ga door naar hoofdinhoud
HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Power off Device.
    • Working device while it is powered on may cause damage to laptop or electric shock.
  2. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip over laptop
    • Remove the rubber foot with a Metal Spudger
  3. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws.
    • 5 Phillips 2.0 x 5.0 mm screws.
    • Make sure to keep different screw types separated.
  4. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Flip the laptop over to screen and keyboard side.
    • Using a Metal Spudger pop open keyboard from base of laptop.
    • Be cautious of three wires on the inside of the keyboard connecting it to the motherboard.
  5. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
  6. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: stap 6, afbeelding 2 van 2
    • After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
k.kolish2493 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 726
