Ga door naar hoofdinhoud
HP Pavilion x360 m3-u103dx Fan Replacement
Wat je nodig hebt
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx Fan Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx Fan Replacement: stap 3, afbeelding 3 van 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx Fan Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Fan Replacement: stap 6, afbeelding 2 van 2
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,314
