Ga door naar hoofdinhoud
HP Pavilion x360 m3-u103dx Battery Replacement
Wat je nodig hebt
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: stap 4, afbeelding 1 van 3 HP Pavilion x360 m3-u103dx Battery Replacement: stap 4, afbeelding 2 van 3 HP Pavilion x360 m3-u103dx Battery Replacement: stap 4, afbeelding 3 van 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: stap 5, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: stap 7, afbeelding 1 van 2 HP Pavilion x360 m3-u103dx Battery Replacement: stap 7, afbeelding 2 van 2
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Can i use the laptop even without a battery??
PAPISSS PH - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 6,845
