Inleiding
If the speakers are malfunctioning, use this guide to replace them.
Wat je nodig hebt
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Gereedschap gebruikt in deze stap:Heavy-Duty Spudger$4.99
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
(You don't NEED to remove this shielding as you can remove the board with it still there.)
Remove the adhesive strip.
Lift the shield away from the base of the laptop.
Disconnect the ribbon cables attached to the system board (motherboard).
Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Follow these instructions in reverse order to reassemble your device.
