Inleiding
The battery is defective if the power is draining quickly after a full charge, or doesn't receive charge at all. Then use this guide.
Wat je nodig hebt
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
Follow these instructions in reverse order to reassemble your device.
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks for this easy step by step guide. The pictures were incredibly helpful!
