Inleiding
If your laptop does not turn on or USB ports are malfunctioning, the system board may need to be replaced. To replace the system board, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Wat je nodig hebt
Power off your device and disconnect all external devices connected to the laptop.
Gereedschap gebruikt in deze stap:Heavy-Duty Spudger$4.99
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
8 Phillips 2.0 x 4.7 mm screws.
Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
