Ga door naar hoofdinhoud
HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement
Wat je nodig hebt
  1. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: stap 1, afbeelding 1 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: stap 1, afbeelding 2 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: stap 1, afbeelding 3 van 3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 2, afbeelding 1 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 2, afbeelding 2 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 2, afbeelding 3 van 3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 3, afbeelding 3 van 3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 4, afbeelding 2 van 2
    • Pinch and lift the black and gray plate labeled with "WLAN."
  5. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 5, afbeelding 1 van 1
    • Use the spudger to unhook the locks on each side of the green RAM stick.
    • The locks will be unhooked by pushing them gently away from the RAM sticks.
  6. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the RAM stick up and out to remove.
    • Repeat the previous two steps to remove the second RAM strip.
Conclusie
Amber Norton
661 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 313
