Ga door naar hoofdinhoud
HP Pavilion x360 15t-br000 Motherboard Replacement
Wat je nodig hebt
  1. HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 1 van 3 HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 2 van 3 HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 3 van 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Pavilion x360 15t-br000 Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Pavilion x360 15t-br000 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 15t-br000 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 HP Pavilion x360 15t-br000 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Disconnect the five cable connections to the motherboard.
  6. HP Pavilion x360 15t-br000 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
  7. HP Pavilion x360 15t-br000 Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Pavilion x360 15t-br000 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Lift the motherboard carefully then remove the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 297
