Ga door naar hoofdinhoud
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
Wat je nodig hebt
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: stap 1, afbeelding 1 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: stap 1, afbeelding 2 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: stap 1, afbeelding 3 van 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 2, afbeelding 1 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 2, afbeelding 2 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 2, afbeelding 3 van 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: stap 3, afbeelding 1 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: stap 3, afbeelding 2 van 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: stap 3, afbeelding 3 van 3
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 5, afbeelding 1 van 1
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 522
