Inleiding
Use this guide to replace the battery in your HP Pavilion x360 15t-br000 laptop.
If your battery is damaged, you can’t open the laptop. A damaged battery may cause the laptop to shut down and you will lose your data.
Don’t connect to the power when doing the replacement.
Wat je nodig hebt
Remove the covers to access the screws attached to the back cover of the device.
Remove six 3mm screws using the Phillips #0 screwdriver.
Bijna klaar!
Conclusie
