Ga door naar hoofdinhoud
HP Pavilion x360 14m-cd0005dx Motherboard Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: stap 6, afbeelding 1 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: stap 6, afbeelding 2 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: stap 6, afbeelding 3 van 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Heat Sink and Fan: stap 8, afbeelding 1 van 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 10, afbeelding 1 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 10, afbeelding 2 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 11, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Remove all screws securing the motherboard to the device:
    • Ten Phillips #0 4.5mm screws
  13. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 13, afbeelding 1 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 13, afbeelding 2 van 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 13, afbeelding 3 van 3
    Koop
    • Use the Reverse Tweezers to disconnect the speaker cables from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 14, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Slide out the ribbon wire from the motherboard
  15. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 15, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Gently lift the motherboard out of the device
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 29
Altijd: 719
