Ga door naar hoofdinhoud
HP Pavilion x360 14m-cd0005dx Back Cover Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14m-cd0005dx Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 3, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: stap 5, afbeelding 3 van 3
    • Using the opening tool, carefully remove the bottom cover from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 3,516
