Ga door naar hoofdinhoud
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 2, afbeelding 2 van 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 3, afbeelding 3 van 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: stap 4, afbeelding 1 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: stap 4, afbeelding 2 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: stap 4, afbeelding 3 van 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Conclusie
Elijah Jope
376 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Lid van UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 373
