Ga door naar hoofdinhoud
HP Pavilion x360 14m-cd0003dx Fan Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 2, afbeelding 2 van 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 3, afbeelding 1 van 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 4, afbeelding 1 van 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the heat sink assembly from the device.
Conclusie
Riley McMorrow
240 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Lid van UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 456
