Ga door naar hoofdinhoud
HP Pavilion x360 14m-ba011dx SSD Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14m-ba011dx SSD Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion x360 14m-ba011dx SSD Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 2, afbeelding 1 van 1
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 3, afbeelding 1 van 2 HP Pavilion x360 14m-ba011dx SSD Replacement: stap 3, afbeelding 2 van 2
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x360 14m-ba011dx SSD Replacement: stap 4, afbeelding 2 van 2
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx SSD Replacement, Motherboard: stap 6, afbeelding 1 van 2 HP Pavilion x360 14m-ba011dx SSD Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Unclip the 5 cables connecting the motherboard to the computer.
  7. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 7, afbeelding 1 van 1
    • Remove ten 4 mm screws using a Phillips #00 screwdriver.
  8. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the motherboard.
  9. HP Pavilion x360 14m-ba011dx SSD Replacement, SSD: stap 9, afbeelding 1 van 3 HP Pavilion x360 14m-ba011dx SSD Replacement, SSD: stap 9, afbeelding 2 van 3 HP Pavilion x360 14m-ba011dx SSD Replacement, SSD: stap 9, afbeelding 3 van 3
    • Flip the motherboard over to expose the SSD.
    • Using a Phillips #00 screwdriver, remove one 3 mm silver screw that holds the SSD in place.
  10. HP Pavilion x360 14m-ba011dx SSD Replacement: stap 10, afbeelding 1 van 1
    • Carefully lift and remove the SSD assembly by gently sliding it out of its slot.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 78
Altijd: 3,046
