Ga door naar hoofdinhoud
HP Pavilion x360 14-ba253cl Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kristen Gismondi
84.850 Reputatie
215 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
Één opmerking
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 55
Altijd: 7,110
