Inleiding
This guide demonstrates how to replace the touchpad on a HP Pavilion x360 11-p110nr. The entire process is fairly quick and easy, and with a bit of care, it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around electricity and always unplug the battery before you attempt to replace any part of the laptop.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Once the screws are removed, carefully take the bottom plate off.
