Ga door naar hoofdinhoud
HP Pavilion x360 11-p110nr Speakers Replacement
Wat je nodig hebt
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: stap 1, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: stap 1, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: stap 1, afbeelding 3 van 3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: stap 2, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 2, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 2, afbeelding 3 van 3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 3, afbeelding 3 van 3
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: stap 4, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 4, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: stap 6, afbeelding 1 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 6, afbeelding 2 van 3 HP Pavilion x360 11-p110nr Speakers Replacement: stap 6, afbeelding 3 van 3
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
Conclusie
Aeorrell
433 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-2, Harley Spring 2023 Lid van IUPUI, Team 1-2, Harley Spring 2023
IUPUI-HARLEY-S23S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 71
