Ga door naar hoofdinhoud
HP Pavilion x2 10-n113dx Speaker Replacement
Wat je nodig hebt
  1. HP Pavilion x2 10-n113dx Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Speaker Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Speaker Replacement: stap 2, afbeelding 2 van 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Speaker Replacement: stap 3, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 3, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 3, afbeelding 3 van 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Speaker Replacement: stap 4, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 4, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 4, afbeelding 3 van 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Speaker Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 5, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: stap 6, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: stap 6, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: stap 6, afbeelding 3 van 3
    • To unscrew the first speaker, use the Phillips #0 screwdriver to unscrew the 2 screws- head 3.99mm, length 3.32 mm.
  7. HP Pavilion x2 10-n113dx Speaker Replacement: stap 7, afbeelding 1 van 1
    • For the second speaker, repeat the previous step by unscrewing the two screws.
  8. HP Pavilion x2 10-n113dx Speaker Replacement: stap 8, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 8, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Speaker Replacement: stap 8, afbeelding 3 van 3
    • Gently remove the 1st and 2nd speaker from the assembly.
Conclusie
David Zambrano
822 Reputatie
5 handleidingen geschreven
USF Tampa, Team S13-G4, Boczar Fall 2017 Lid van USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 522
