Inleiding
If the HP Pavilion X2's power isn't working, the battery may need to be changed. This guide shows how to take apart the HP Pavilion X2 to expose the screen and therefore take it apart to replace it with a new one.
Wat je nodig hebt
Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
3.32 mm head, 3.99 mm length.
2.82 head 3.5 mm length.
4.15 mm head, 2.35 mm length.
5 andere personen hebben deze handleiding voltooid.
4 opmerkingen
where can i get the replacement screen for this model
where can i get the replacement screen for this model?
This guide is bad. He takes the same screws out twice. There is more than 21 screws. Do not follow this guide you will end up breaking something.
