Ga door naar hoofdinhoud
HP Pavilion x2 10-n113dx Hinge Replacement
Wat je nodig hebt
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: stap 1, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: stap 1, afbeelding 2 van 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Hinge Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Hinge Replacement: stap 4, afbeelding 2 van 2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: stap 5, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 5, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 5, afbeelding 3 van 3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: stap 6, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Hinge Replacement: stap 6, afbeelding 2 van 2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: stap 8, afbeelding 1 van 1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: stap 9, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 9, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 9, afbeelding 3 van 3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: stap 10, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 10, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Hinge Replacement: stap 10, afbeelding 3 van 3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
Conclusie
Ajay Panuganti
181 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G4, Harley Spring 2019 Lid van IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,142
