Ga door naar hoofdinhoud
HP Pavilion x2 10-n113dx Camera Replacement
Wat je nodig hebt
  1. HP Pavilion x2 10-n113dx Camera Replacement, Camera: stap 1, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: stap 1, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: stap 1, afbeelding 3 van 3
    • Separate the screen from the keyboard.
    • The keyboard and screen are held together via magnets.
    • Open the device and pull the screen parallel to its face.
  2. HP Pavilion x2 10-n113dx Camera Replacement: stap 2, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Camera Replacement: stap 2, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Camera Replacement: stap 2, afbeelding 3 van 3
    • Separate the screen from body of the computer with a blue spudger.
    • Using a plastic spudger, gently begin separating the face from the body.
    • Separate each side gently.
  3. HP Pavilion x2 10-n113dx Camera Replacement: stap 3, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Camera Replacement: stap 3, afbeelding 2 van 2
    • Once each edge has been separated, gently lift the face (screen) from the back.
    • Be sure to not do so quickly or you risk tearing the keyboard ribbon cable.
    • Rotate the device 180 degrees for the following steps.
  4. HP Pavilion x2 10-n113dx Camera Replacement: stap 4, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Camera Replacement: stap 4, afbeelding 2 van 2
    • Follow the attached ribbon cable to the circuit board of the device.
    • On the side of the ribbon cable, use a small plastic spudger to pop open this plastic lock and gently pull in the direction of the cable to remove.
    • Gently lift up on the battery connector just below the earlier removed ribbon cable to remove.
  5. HP Pavilion x2 10-n113dx Camera Replacement: stap 5, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Camera Replacement: stap 5, afbeelding 2 van 2
    • Unscrew and remove each of the four indicated screws using the Phillips #0 screwdriver.
    • Begin with the bottom left 4.5mm diameter screw.
    • Continue to the remaining three 2.0 mm diameter screws.
    • Once all four screws have been removed lift the battery from the device using the indicated pull tab along the top edge.
  6. HP Pavilion x2 10-n113dx Camera Replacement: stap 6, afbeelding 1 van 3 HP Pavilion x2 10-n113dx Camera Replacement: stap 6, afbeelding 2 van 3 HP Pavilion x2 10-n113dx Camera Replacement: stap 6, afbeelding 3 van 3
    • Using a small blue plastic spudger pop off the two speaker wires from the circuit board.
    • Once removed from the board carefully move the wires from the raised clips on the metal plating.
  7. HP Pavilion x2 10-n113dx Camera Replacement: stap 7, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 4.5mm screw from the camera circuit board.
    • Using a plastic spudger flip up the two rubber covers to the right and left of the 4.5mm screw.
  8. HP Pavilion x2 10-n113dx Camera Replacement: stap 8, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Camera Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully remove the ribbon cable from the camera circuit board with tweezers.
    • Carefully remove the wire mesh tape from the metal plating using tweezers.
  9. HP Pavilion x2 10-n113dx Camera Replacement: stap 9, afbeelding 1 van 2 HP Pavilion x2 10-n113dx Camera Replacement: stap 9, afbeelding 2 van 2
    • Using a plastic spudger remove the camera circuit board from the device.
Conclusie
Cayla Skaggs
337 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G4, Harley Spring 2019 Lid van IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 457
