Inleiding
This guide provides instructions on the disassembly of the HP Pavilion tx2500 for fan replacement.
Wat je nodig hebt
Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
Disconnect the wire from the system board using the plastic opening tool.
Disconnect the wire from the optical drive using the plastic opening tool.
Gently lift the top cover from the tablet.
Één andere persoon heeft deze handleiding voltooid.
