Ga door naar hoofdinhoud
HP Pavilion g7-2275dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: stap 1, afbeelding 1 van 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion g7-2275dx Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion g7-2275dx Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: stap 6, afbeelding 1 van 2 HP Pavilion g7-2275dx Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: stap 7, afbeelding 1 van 2 HP Pavilion g7-2275dx Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove the plastic cover from the hard drive.
Conclusie
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
5 andere personen hebben deze handleiding voltooid.
Erik Miller
2.123 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-51, Amido Spring 2014 Lid van Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 4,945
