Ga door naar hoofdinhoud
HP Pavilion g7-2275dx Fan Replacement
Wat je nodig hebt
  1. HP Pavilion g7-2275dx Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    There is no realistic risk of electric shock on a laptop. However, is it still advisable to disconnect power plug and battery before opening as there is a real risk of accidental damage by short-circuit.
    antoniotavares - Antwoord
  2. HP Pavilion g7-2275dx Fan Replacement: stap 2, afbeelding 1 van 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Fan Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: stap 3, afbeelding 1 van 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Fan Replacement: stap 4, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 4, afbeelding 2 van 2
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Fan Replacement, Hard Drive: stap 5, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement, Hard Drive: stap 5, afbeelding 2 van 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  6. HP Pavilion g7-2275dx Fan Replacement: stap 6, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 6, afbeelding 2 van 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  7. HP Pavilion g7-2275dx Fan Replacement, RAM: stap 7, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement, RAM: stap 7, afbeelding 2 van 2
    • Use your fingers, plastic opening tools, or pliers to pull the silver brackets away from the RAM.
    • The RAM should pop up to a 35 degree angle.
  8. HP Pavilion g7-2275dx Fan Replacement: stap 8, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 8, afbeelding 2 van 2
    • Gently pull the RAM straight out in the direction it currently is orientated.
    • When inserting new RAM, place the RAM in the black housing at a 35 degree angle (it will fit loosely), then push down until it clicks into the silver brackets.
    • This computer supports two sticks of RAM. To add a second stick, repeat the above step with the upper black housing. (Ensure that you have the correct size and type of RAM before trying to add it).
    This laptop only supports up to 8 gig of ram (2x 4)
    Kip Bunn - Antwoord
  9. HP Pavilion g7-2275dx Fan Replacement, Wireless Card: stap 9, afbeelding 1 van 1
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  10. HP Pavilion g7-2275dx Fan Replacement: stap 10, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 10, afbeelding 2 van 2
    • Use a plastic opening tool to lift the wireless card out of its slot.
    In replacing the wireless card, I found it easiest to insert the wireless card and screw down before reattaching the wires. A strong pair of forceps or tweezers helped align the male and female connectors, which are quite small.
    jawolf3 - Antwoord
  11. HP Pavilion g7-2275dx Fan Replacement: stap 11, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 11, afbeelding 2 van 2
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
  12. HP Pavilion g7-2275dx Fan Replacement, Back panel screws: stap 12, afbeelding 1 van 1
    • Remove sixteen 7 mm Phillips #1 screws.
  13. HP Pavilion g7-2275dx Fan Replacement, Keyboard: stap 13, afbeelding 1 van 1
    • Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
    The CD/DVD drive can also be removed at this point to prevent it from slipping out of the case during repair. Simply slide it out. (remember to re-install before replacing the back panel screws)
    Kip Bunn - Antwoord
  14. HP Pavilion g7-2275dx Fan Replacement: stap 14, afbeelding 1 van 1
    • Flip the laptop over and open the screen.
  15. HP Pavilion g7-2275dx Fan Replacement: stap 15, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 15, afbeelding 2 van 2
    • A ribbon cable is attached to the back of the keyboard. Avoid lifting or moving the keyboard more than a couple inches before you disconnect the ribbon cable or you may damage it.
    • Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
    • The keyboard may make some cracking noises as you pry it from the casing. This is expected.
    • Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
  16. HP Pavilion g7-2275dx Fan Replacement: stap 16, afbeelding 1 van 1
    • Gently turn keyboard over, towards you, to reveal the silver cable ribbon.
  17. HP Pavilion g7-2275dx Fan Replacement: stap 17, afbeelding 1 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 17, afbeelding 2 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 17, afbeelding 3 van 3
    • Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
  18. HP Pavilion g7-2275dx Fan Replacement, Front Panel: stap 18, afbeelding 1 van 1
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  19. HP Pavilion g7-2275dx Fan Replacement: stap 19, afbeelding 1 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 19, afbeelding 2 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 19, afbeelding 3 van 3
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
    Petit oubli: Il faut aussi déconnecté la nappe qui se trouve en haut à gauche.
    Jay - Antwoord
  20. HP Pavilion g7-2275dx Fan Replacement: stap 20, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 20, afbeelding 2 van 2
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  21. HP Pavilion g7-2275dx Fan Replacement: stap 21, afbeelding 1 van 1
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  22. HP Pavilion g7-2275dx Fan Replacement: stap 22, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 22, afbeelding 2 van 2
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
  23. HP Pavilion g7-2275dx Fan Replacement, Fan: stap 23, afbeelding 1 van 1
    • Unscrew one 7 mm Phillips #1 screw from the bottom left corner of the motherboard.
  24. HP Pavilion g7-2275dx Fan Replacement: stap 24, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 24, afbeelding 2 van 2
    • Lift black tab for the CD drive cable in the bottom left of the motherboard.
    • Disconnect it from the motherboard with your fingers or a plastic opening tool.
  25. HP Pavilion g7-2275dx Fan Replacement: stap 25, afbeelding 1 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 25, afbeelding 2 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 25, afbeelding 3 van 3
    • Lift, with your fingers or a plastic opening tool, the large black monitor cable at the top of the left hand corner of the motherboard.
  26. HP Pavilion g7-2275dx Fan Replacement: stap 26, afbeelding 1 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 26, afbeelding 2 van 3 HP Pavilion g7-2275dx Fan Replacement: stap 26, afbeelding 3 van 3
    • Use a plastic opening tool to lift the black clip up from the silver cable that's in the upper right hand corner of the computer.
    • Pull the silver cable away from the motherboard.
  27. HP Pavilion g7-2275dx Fan Replacement: stap 27, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 27, afbeelding 2 van 2
    • Using a small amount of force pull the black cable, below the silver cable we just removed, to the right and out of the way.
  28. HP Pavilion g7-2275dx Fan Replacement: stap 28, afbeelding 1 van 1
    • Lift the right side of the motherboard up at roughly a 45 degree angle and pull to the right to remove it.
  29. HP Pavilion g7-2275dx Fan Replacement: stap 29, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 29, afbeelding 2 van 2
    • Now that the motherboard is out, flip it over and begin working on the back side.
    • Remove the red, blue, and yellow set of wires from the motherboard.
  30. HP Pavilion g7-2275dx Fan Replacement: stap 30, afbeelding 1 van 2 HP Pavilion g7-2275dx Fan Replacement: stap 30, afbeelding 2 van 2
    • The screws on the heat sink are held in place by screws and stoppers; they will unscrew, but will not come out of the heat sink. Be careful not to loosen them too much or you may damage the bracket on the back of the CPU.
    • Using a Phillips #1 screw driver unscrew the four screws on the heat sink.
    • When tightening the screws during reassembly, tighten them in a cross pattern (start by tightening the upper left screw, then the bottom right screw, then the top right screw, and finally the bottom left screw)
    • Lift the bracket up from the motherboard.
    What type of screw is into the CPU?
    EJude Garcia - Antwoord
  31. HP Pavilion g7-2275dx Fan Replacement: stap 31, afbeelding 1 van 1
    • Since the fan is held on with adhesives, you will likely need a prying tool and a small amount of force to lift the fan up and off of the motherboard.
    • Be sure to apply a light coating of thermal paste to the CPU before you screw the heat sink back on. For help applying thermal paste, you can reference the iFixit Thermal Paste Application guide
    Where can l purchase a fan
    Sherry Ashton - Antwoord
    This is ridiculous !! why is there not a separate opening/doorway/removable panel so that you can get straight to the Fan ? ? because with this design you literally have to take the whole dam laptop apart…31 steps just to clean or replace a fan ?? who was the moron that came up with this retarded design ??
    I use to think the people at HP were pretty smart…Not anymore…never buying anything from HP again
    bifbarnes - Antwoord
    I’ve disassembled mine twice with no problems. Try yoga to relieve all that frustration.
    Kip Bunn -
    Excellent teardown. I don't need to replace the fan (yet!), but needed to get the laptop apart to find out why when I opened it yesterday, suddenly it's like the case was being pried open.
    Any idea on whether or not just the back piece of the case can be replaced?? Appears the plastic where the bracket screws into cracked apart, so there's nothing to hold the bracket in place while it pivots open & that was pushing the case apart. Going to Macgyver something for now… and heck, might as well clean it all while it's open, lol!
    Cici - Antwoord
Conclusie
45 andere personen hebben deze handleiding voltooid.
John Sutton
1.566 Reputatie
8 handleidingen geschreven
Cal Poly, Team 11-51, Amido Spring 2014 Lid van Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Leden
21 handleidingen geschreven
16 opmerkingen
I had to stop at stap 14 because i couldnt open my laptop, lifting the screen took the plastic piece around the keyboard loose. I tried to return my staps ( to still have a computer) but that plastic piece wont fit back. And i,still cant open my screen.
hendrikvandervelden - Antwoord
This worked well for accessing and cleaning the fan. Thanks.
alisl ahish - Antwoord
I just wanted to say THANK YOU for posting this instructional page. I know this took a lot of time on your part plus you done this for free to boot. It is because of people like you that make the lives of others PC life much MUCH easier!
Edward Norton - Antwoord
Thank you so much! It helped me a lot although I had a different g7 model.
Raimund von der Emden - Antwoord
Thanks!!! I was able to fix my laptop.
mdoming58182 - Antwoord
Thank you John! Your instructions were clear and the numbering helped me a lot in separating the various components and screws.
One point - in step 20- I disconnected a cable from a connector, roughly under where the esc key or the ~ key are. It is not mentioned in the description here. It may be that my model is different - G7-2022US.
Yaacov - Antwoord
Thank you so much for this tutorial! The repair shop quoted me $150 and 2 weeks to fix this, and I was able to fix this in about an hour for under $20. :) I JUST replaced the fan (heat sink was fine) so to remove it, I also had to use a teeny-tiny screwdriver (even smaller than an eyeglass repair kit size) to remove the existing screws that held the fan in place.. Other than that everything else was perfect. I have ZERO experience in repairing laptop innards, first time here, so this was exactly what I needed. It works perfectly now! While i was in there I went ahead and added 4GB RAM, so it's faster now also. THANK YOU!
sigkapgirl - Antwoord
Hey.. which (for replacing the fan) screwdrivers were you talking about? Phillips #1 Screwdriver doesn't work? Did you need something else?
Aditya Putatunda -
Thank you!! Absolutely perfect! thanks for taking the time to post!
bergahoo - Antwoord
Very Very nice layed out instruction guide. My laptop fan stopped working after spraying it with compressed air so i had to take it apart but had no idea where to start and after following the simple instruction guide i managed to find a very large piece of lint the size of a nickel lodged inside one of the internal parts of the fan which caused it to stop working. Without this guide i would not have been able to do that,
Thank you again for the very easy completely layed out instructions, very simple to follow.
saschaheinzel - Antwoord
What a bad design. This process makes me want to google the price of a new laptop….lol
Thanks
James Lawson - Antwoord
Thanks was able to fix my keyboard and did a thermalpaste swap :) extremly helpful
Marten M - Antwoord
I followed exactly step by step being super gentle and after putting it all back together my laptop will not turn on now. I'm so upset right now.
Sondra Gabel - Antwoord
I had to lube the fan bearing because otherwise it would throw an error when posting and make a horrible, and the guide was just perfect, thanks!
:!: Dan3λ :!: - Antwoord
Absolutely wonderful tutorial, easy to follow with concise, well-worded “cautions” where appropriate. Impressively thorough. Thank you very much for this helpful compilation.
Linda D - Antwoord
Perfect instructions, well done
Jeff LeBlanc - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 64
Altijd: 41,878
