Inleiding
There are a few reasons to remove/replace the service door. The service door is cracked, the screw that is attached to the service door is stripped, or you simply need to access the internal parts of the device. Whatever the reason, this guide will show you how to remove and replace the service door.
Wat je nodig hebt
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Bijna klaar!
Conclusie
